C# 编程WinForm 上传文件到 Asp.Net 的 Web项目
2017年3月22日 0:15 本文热度 6860
在做WinForm时,需要WinForm同Web进行交互,有时需要进行图片、文件的上传操作.
WinForm的代码如下:
C#代码  收藏代码
  1. private void button2_Click(object sender, EventArgs e)
  2.         {
  3.             // string a = MyUploader(this.textBox1.Text.Trim(), @"http://localhost:4451/TEST/Default.aspx");
  4.
  5.             string a = MyUploader(this.textBox1.Text.Trim(), @"http://localhost/release/Default.aspx");
  6.
  7.           MessageBox.Show(a);
  8.         }
  9.
  10.
  11.         public static string MyUploader(string strFileToUpload, string strUrl)
  12.         {
  13.             string strFileFormName = "file";
  14.             Uri oUri = new Uri(strUrl);
  15.             string strBoundary = "----------" + DateTime.Now.Ticks.ToString("x");
  16.
  17.             // The trailing boundary string
  18.             byte[] boundaryBytes = Encoding.ASCII.GetBytes("\r\n--" + strBoundary + "\r\n");
  19.
  20.             // The post message header
  21.             StringBuilder sb = new StringBuilder();
  22.             sb.Append("--");
  23.             sb.Append(strBoundary);
  24.             sb.Append("\r\n");
  25.             sb.Append("Content-Disposition: form-data; name=\"");
  26.             sb.Append(strFileFormName);
  27.             sb.Append("\"; filename=\"");
  28.             sb.Append(Path.GetFileName(strFileToUpload));
  29.             sb.Append("\"");
  30.             sb.Append("\r\n");
  31.             sb.Append("Content-Type: ");
  32.             sb.Append("application/octet-stream");
  33.             sb.Append("\r\n");
  34.             sb.Append("\r\n");
  35.             string strPostHeader = sb.ToString();
  36.             byte[] postHeaderBytes = Encoding.UTF8.GetBytes(strPostHeader);
  37.
  38.             // The WebRequest
  39.             HttpWebRequest oWebrequest = (HttpWebRequest)WebRequest.Create(oUri);
  40.             oWebrequest.ContentType = "multipart/form-data; boundary=" + strBoundary;
  41.             oWebrequest.Method = "POST";
  42.
  43.             // This is important, otherwise the whole file will be read to memory anyway...
  44.             oWebrequest.AllowWriteStreamBuffering = false;
  45.
  46.             // Get a FileStream and set the final properties of the WebRequest
  47.             FileStream oFileStream = new FileStream(strFileToUpload, FileMode.Open, FileAccess.Read);
  48.             long length = postHeaderBytes.Length + oFileStream.Length + boundaryBytes.Length;
  49.             oWebrequest.ContentLength = length;
  50.             Stream oRequestStream = oWebrequest.GetRequestStream();
  51.
  52.             // Write the post header
  53.             oRequestStream.Write(postHeaderBytes, 0, postHeaderBytes.Length);
  54.
  55.             // Stream the file contents in small pieces (4096 bytes, max).
  56.             byte[] buffer = new Byte[checked((uint)Math.Min(4096, (int)oFileStream.Length))];
  57.             int bytesRead = 0;
  58.             while ((bytesRead = oFileStream.Read(buffer, 0, buffer.Length)) != 0)
  59.                 oRequestStream.Write(buffer, 0, bytesRead);
  60.             oFileStream.Close();
  61.
  62.             // Add the trailing boundary
  63.             oRequestStream.Write(boundaryBytes, 0, boundaryBytes.Length);
  64.             WebResponse oWResponse = oWebrequest.GetResponse();
  65.             Stream s = oWResponse.GetResponseStream();
  66.             StreamReader sr = new StreamReader(s);
  67.             String sReturnString = sr.ReadToEnd();
  68.             Console.WriteLine(sReturnString);
  69.             // Clean up
  70.             oFileStream.Close();
  71.             oRequestStream.Close();
  72.             s.Close();
  73.             sr.Close();
  74.
  75.             return sReturnString;
  76.         }
在按钮点击时,便会触发提交操作,Web的Default.aspx代码如下:
C#代码  收藏代码
  1. public partial class _Default : System.Web.UI.Page
  2. {
  3.     protected void Page_Load(object sender, EventArgs e)
  4.     {
  5.         if (Request.Files.Count > 0)
  6.         {
  7.             try
  8.             {
  9.                 HttpPostedFile file = Request.Files[0];
  10.                 string filePath = this.MapPath("FileUpload") + "\\" + file.FileName;
  11.                 file.SaveAs(filePath);
  12.
  13.                 Response.Write("成功了");
  14.
  15.             }
  16.             catch (Exception)
  17.             {
  18.
  19.                 Response.Write("失败了1");
  20.             }
  21.         }
  22.         else
  23.         {
  24.             Response.Write("失败了2");
  25.         }
  26.
  27.         Response.End();
  28.     }
  29. }
这样,便可以将文件通过winform 上传到web 服务器上。
该文章在 2017/3/22 0:15:30 编辑过
