winform下用FileStream实现多文件上传
2017年3月22日 0:41 本文热度 7578
先看效果图:
代码:
[csharp] view plain copy
 print?
  1. using System;
  2. using System.Collections.Generic;
  3. using System.ComponentModel;
  4. using System.Data;
  5. using System.Drawing;
  6. using System.Linq;
  7. using System.Text;
  8. using System.Windows.Forms;
  9. using System.IO;
  10. using System.Collections;
  11. using System.Threading;
  12.
  13. namespace VideoTrans
  14. {
  15.     public partial class Form2 : Form
  16.     {
  17.         public Form2()
  18.         {
  19.             InitializeComponent();
  20.             LoadListView();
  21.             this.FormClosed += (sender, e) => {
  22.                 Application.Exit();
  23.                 System.Diagnostics.Process pro = System.Diagnostics.Process.GetCurrentProcess();
  24.                 pro.Kill();
  25.             };
  26.         }
  27.         /// <summary>
  28.         /// 初始化上传列表
  29.         /// </summary>
  30.         void LoadListView()
  31.         {
  32.             listView1.View = View.Details;
  33.             listView1.CheckBoxes = true;
  34.             listView1.GridLines = true;
  35.             listView1.Columns.Add("文件名",150,HorizontalAlignment.Center);
  36.             listView1.Columns.Add("文件大小", 150, HorizontalAlignment.Center);
  37.             listView1.Columns.Add("文件路径", 150, HorizontalAlignment.Center);
  38.         }
  39.         /// <summary>
  40.         /// 存储目录
  41.         /// </summary>
  42.         /// <param name="sender"></param>
  43.         /// <param name="e"></param>
  44.         private void button2_Click(object sender, EventArgs e)
  45.         {
  46.             FolderBrowserDialog fbd = new FolderBrowserDialog();
  47.             if(fbd.ShowDialog()==DialogResult.OK)
  48.             {
  49.                 textBox1.Text=fbd.SelectedPath;
  50.             }
  51.         }
  52.         /// <summary>
  53.         /// 打开上传文件
  54.         /// </summary>
  55.         /// <param name="sender"></param>
  56.         /// <param name="e"></param>
  57.         private void button3_Click(object sender, EventArgs e)
  58.         {
  59.
  60.             OpenFileDialog ofd = new OpenFileDialog();
  61.             ofd.Multiselect = true;
  62.             if(ofd.ShowDialog()==DialogResult.OK)
  63.             {
  64.                 foreach(string filename in ofd.FileNames)
  65.                 {
  66.                     FileInfo fi=new FileInfo(filename);
  67.                     ListViewItem lvi = new ListViewItem(Path.GetFileNameWithoutExtension(filename));
  68.                     lvi.Tag = filename;
  69.                     lvi.SubItems.Add(fi.Length.ToString());
  70.                     //lvi.SubItems.Add((fi.Length / (1024 * 1024)).ToString() + "M");
  71.                     lvi.SubItems.Add(Path.GetDirectoryName(filename));
  72.                     listView1.Items.Add(lvi);
  73.                 }
  74.
  75.             }
  76.         }
  77.         public delegate void DeleFile(int position);
  78.         /// <summary>
  79.         /// 文件上传
  80.         /// </summary>
  81.         /// <param name="sender"></param>
  82.         /// <param name="e"></param>
  83.         private void button1_Click(object sender, EventArgs e)
  84.         {
  85.
  86.             if (textBox1.Text.Trim().Equals(""))
  87.             {
  88.                 MessageBox.Show("请先选择存储目录..!");
  89.             }
  90.             else
  91.             {
  92.
  93.                 if (listView1.Items.Count > 0)
  94.                 {
  95.                     int j = 0;
  96.                     string count = listView1.CheckedItems.Count.ToString();
  97.                     for (int i = 0; i < listView1.Items.Count;i++ )
  98.                     {
  99.
  100.                         if (listView1.Items[i].Checked)
  101.                         {
  102.                             j++;
  103.                             string fileName = Path.GetFileName(listView1.Items[i].Tag.ToString());
  104.                             label1.Text = string.Format("正在上传文件:[{0}]", listView1.Items[i].Text) + ":" + j.ToString() + ":" + count;
  105.                             FileStream des = new FileStream(Path.Combine(textBox1.Text, fileName), FileMode.OpenOrCreate, FileAccess.Write);
  106.                             FileStream fir = new FileStream(listView1.Items[i].Tag.ToString(), FileMode.Open, FileAccess.Read);
  107.                             byte[] buffer = new byte[10240];
  108.                             int size = 0; int ren = 0;
  109.                             while (ren < fir.Length)
  110.                             {
  111.                                 Application.DoEvents();
  112.                                 size = fir.Read(buffer,0,buffer.Length);
  113.                                 des.Write(buffer, 0, size);
  114.                                 ren += size;
  115.                                 Pro(ren);
  116.                             }
  117.                             listView1.Items[i].Checked = false;
  118.                         }
  119.                         else
  120.                         {
  121.                             continue;
  122.                         }
  123.                     }
  124.                     //MessageBox.Show("上传成功!");
  125.                 }
  126.                 else
  127.                 {
  128.                     return;
  129.                 }
  130.             }
  131.
  132.         }
  133.         public void Pro(int copy)
  134.         {
  135.
  136.             if (this.progressBarEx1.InvokeRequired)
  137.             {
  138.                 this.progressBarEx1.Invoke(new DeleFile(Pro),new object[]{copy});
  139.                 return;
  140.             }
  141.             foreach (ListViewItem lvi in listView1.CheckedItems)
  142.             {
  143.                 string total = lvi.SubItems[1].Text;
  144.                 int pro = (int)((float)copy / long.Parse(total) * 100);
  145.                 if (pro <= progressBarEx1.Maximum)
  146.                 {
  147.                     progressBarEx1.Value = pro;
  148.                     progressBarEx1.Text = label1.Text.Split('':'')[0].ToString() + Environment.NewLine + string.Format("上传进度:{0}%", pro) + Environment.NewLine + string.Format("已上传文件数:{0}/{1}", label1.Text.Split('':'')[1].ToString(), label1.Text.Split('':'')[2].ToString());
  149.
  150.                 }
  151.             }
  152.
  153.         }
  154.         /// <summary>
  155.         /// 删除文件
  156.         /// </summary>
  157.         /// <param name="sender"></param>
  158.         /// <param name="e"></param>
  159.         private void button4_Click(object sender, EventArgs e)
  160.         {
  161.             foreach(ListViewItem lvi in listView1.CheckedItems)
  162.             {
  163.                 lvi.Remove();
  164.             }
  165.         }
  166.
  167.     }
  168. }
新手们好好理解,整个程序没什么技术难度,里面的进度条为第三方控件ProgressODoom.dll,自己去网上下。
该文章在 2017/3/22 0:41:28 编辑过
