C#操作注册表二进制数据
2017年5月2日 22:56 本文热度 7197
using System;
using System.Text;
using System.Windows.Forms;
using Microsoft.Win32;
namespace WindowsFormsApplication4
        public Form1()
            InitializeComponent();
        public static byte[] HexStringToByteArray(String hexString)
            int start = 0;
            if (hexString[0] == ''0'' && (hexString[1] == ''x'' || hexString[1] == ''X''))
                start = 2;
            byte[] bytes = new byte[(hexString.Length - start) / 2];
            for (int i = start, len = hexString.Length; i < len; i += 2)
                bytes[i / 2] = Convert.ToByte(hexString.Substring(i, 2), 16);
            return bytes;
        private void button1_Click(object sender, EventArgs e)
            //打开注册表 修改键值
            RegistryKey key = Registry.CurrentUser.OpenSubKey(@"SOFTWARE\ORL\WinVNC3", true);
            var str = "bab3aefe 0f1125fb";
            var bytes = HexStringToByteArray(str.Replace(" ", ""));
            try
                //byte[] array = (byte[])key.GetValue("Password");//获取Password值的字节数组
                //string decoded = System.Text.Encoding.UTF8.GetString(array);//将字节数组转换成字符串
                //decoded = decoded.Replace("\0", String.Empty);//由于将字节数组转换成字符串的过程中,一般会包含\0字符,所以要将它替换成空字符串,否则显示会有问题
                //textBox1.Text = decoded;
                //byte[] bytes = (byte[])key.GetValue("Password");
                //if (bytes == null || bytes.Length < 3)
                key.SetValue("Password", bytes, RegistryValueKind.Binary);
            catch
            MessageBox.Show("ok");
该文章在 2017/5/2 22:56:46 编辑过
