C# websocket与html+js实现文件发送与接收处理
2019年11月12日 18:19 本文热度 5298
服务器端:
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Fleck;
using System.Threading;
using System.IO;
using System.Net.WebSockets;
using System.Net.Sockets;
using System.Net;
namespace ConsoleApplication1
class Program
FleckLog.Level = LogLevel.Debug;
var allSockets = new List<IWebSocketConnection>();
var server = new WebSocketServer("ws://192.168.31.37:7181");
server.Start(socket =>
socket.OnOpen = () =>
Console.WriteLine("Open!");
allSockets.Add(socket);
socket.OnClose = () =>
Console.WriteLine("Close!");
allSockets.Remove(socket);
socket.OnMessage = message =>
Console.WriteLine(message);
allSockets.ToList().ForEach(s => s.Send("Echo: " + message));
socket.OnBinary = file =>
string path = ("D:/test.jpg");
//创建一个文件流
FileStream fs = new FileStream(path, FileMode.Create);
//将byte数组写入文件中
fs.Write(file, 0, file.Length);
//所有流类型都要关闭流,否则会出现内存泄露问题
fs.Close();
//string ss = Console.ReadLine();
var input = File.Open("D://test.jpg",FileMode.Open);
while (true)
Thread.Sleep(2000);
byte[] s = new byte[input.Length];
input.Read(s, 0, s.Length);
foreach (var socket in allSockets.ToList())
socket.Send(s);
input.Close();
input = File.Open("D://test.jpg", FileMode.Open);
客户端:
<!DOCTYPE html>
<html>
<head>
<title>WebSocket Chat Client</title>
<meta charset="utf-8" />
<script type="text/javascript" src="http://apps.bdimg.com/libs/jquery/2.1.1/jquery.js"></script>
<script type="text/javascript" >
//判读浏览器是否支持websocket
$().ready(function() {
if ( !window.WebSocket ) {
alert("童鞋, 你的浏览器不支持该功能啊");
//在消息框中打印内容
function log(text) {
$("#log").append(text+"\n");
//全局的websocket变量
var ws;
//创建连接
$(function() {
$("#uriForm").submit(function() {
log("准备连接到" + $("#uri").val());
ws = new WebSocket($("#uri").val());
//连接成功建立后响应
ws.onopen = function() {
log("成功连接到" + $("#uri").val());
//收到服务器消息后响应
ws.onmessage = function(e) {
//log("收到服务器消息:" + e.data + "''\n");
var reader = new FileReader();
reader.onload=function(eve){
//判断文件是否读取完成
if(eve.target.readyState==FileReader.DONE)
//读取文件完成后,创建img标签来显示服务端传来的字节数//组
var img =document.createElement("img");
//读取文件完成后内容放在this===当前
//fileReader对象的result属性中,将该内容赋值img标签//浏览器就可以自动解析内容格式并且渲染在浏览器中
img.src=this.result;
//将标签添加到id为show的div中否则,即便是有img也看不见
document.getElementById("show").appendChild(img);
//调用FileReader的readAsDataURL的方法自动就会触发onload事件
reader.readAsDataURL(e.data);
//连接关闭后响应
ws.onclose = function() {
log("关闭连接");
$("#disconnect").attr({"disabled":"disabled"});
$("#uri").removeAttr("disabled");
$("#connect").removeAttr("disabled");
ws = null;
$("#uri").attr({"disabled":"disabled"});
$("#connect").attr({"disabled":"disabled"});
$("#disconnect").removeAttr("disabled");
return false;
//发送字符串消息
$(function() {
$("#sendForm").submit(function() {
if (ws) {
var textField = $("#textField");
ws.send(textField.val());
log("我说:" + textField.val());
textField.val("");
textField.focus();
return false;
//发送arraybuffer(二进制文件)
$(function() {
$("#sendFileForm").submit(function() {
var inputElement = document.getElementById("file");
var fileList = inputElement.files;
for ( var i = 0; i < fileList.length; i++) {
console.log(fileList[i]);
log(fileList[i].name);
//发送文件名
ws.send(fileList[i].name);
// reader.readAsBinaryString(fileList[i]);
//读取文件
reader.readAsArrayBuffer(fileList[i]);
// reader.readAsText(fileList[i]);
//文件读取完毕后该函数响应
reader.onload = function loaded(evt) {
var binaryString = evt.target.result;
// Handle UTF-16 file dump
log("\n开始发送文件");
ws.send(binaryString);
return false;
$(function() {
$("#disconnect").click(function() {
if (ws) {
$("#log").empty();
ws.close();
ws = null;
return false;
$(function() {
$("#reset").click(function() {
$("#log").empty();
return false;
</script>
</head>
<body>
<form id="uriForm">
<input type="text" id="uri" value="ws://192.168.31.37:7181"
style="width: 200px;"> <input type="submit" id="connect"
value="Connect"><input type="button" id="disconnect"
value="Disconnect" disabled="disabled">
</form>
<br>
<form id="sendFileForm">
<input id="file" type="file" multiple />
<input type="submit" value="Send" />
<input type="button" id="reset" value="清空消息框"/>
</form>
<br>
<form id="sendForm">
<input type="text" id="textField" value="" style="width: 200px;">
<input type="submit" value="Send">
</form>
<br>
<form>
<textarea id="log" rows="30" cols="100"
style="font-family: monospace; color: red;"></textarea>
</form>
<br>
<div id=''show''></div>
</body>
</html>
该文章在 2019/11/12 18:19:34 编辑过
