C#扩展WebBrowser控件,使其支持拖放文件
2021年2月8日 17:7 本文热度 4561
public partial class UserControl1 : WebBrowser
    private const int WmDropfiles = 0x233;
    [DllImport("shell32.dll")]
    private static extern uint DragQueryFile(IntPtr hDrop, uint iFile, StringBuilder lpszFile, uint cch);
    private static extern void DragAcceptFiles(IntPtr hWnd, bool fAccept);
    protected override void OnHandleCreated(EventArgs e)
        base.OnHandleCreated(e);
        //指示接受文件拖放操作
        if (!DesignMode)
            DragAcceptFiles(Handle, true);
    protected override void WndProc(ref Message m)
        if (m.Msg == WmDropfiles)
            #region 解析消息
            //获取拖放的文件数量
            var count = DragQueryFile(m.WParam, 0xffffffff, null, 0);
            //解析所有播放的文件路径
            var filePaths = new string[count];
            for (uint i = 0; i < count; i++)
                var sb = new StringBuilder();
                DragQueryFile(m.WParam, i, sb, 1024);
                filePaths[i] = sb.ToString();
            #endregion
            //是否继续触发之后的消息处理
            var isCancel = false;
            #region 触发自定义文件拖放事件
            if (DragFile != null)
                var args = new DragFileEventArgs(filePaths);
                DragFile(this, args);
                isCancel = args.IsCancel;
            #endregion
            if (isCancel) return;
        base.WndProc(ref m);
    public event EventHandler<DragFileEventArgs> DragFile;
    public class DragFileEventArgs : EventArgs
        private readonly string[] _filePaths;
        public bool IsCancel { getset; }
        public DragFileEventArgs(string[] filePaths)
            _filePaths = filePaths;
        public string[] FilePaths
            get return _filePaths; }
该文章在 2021/2/8 17:07:23 编辑过
