C# 32位程序自动判断当前操作系统是32位/64位版本并更改注册表实现自动登录Windows和开启某个程序
2021年2月18日 22:32 本文热度 3829
using System;
using System.Linq;
using System.Text;
using Microsoft.Win32;
//判断操作系统版本(64位\32位)打开注册表项
RegistryKey localKey = RegistryKey.OpenBaseKey(RegistryHive.LocalMachine, Environment.Is64BitOperatingSystem ? RegistryView.Registry64 : RegistryView.Registry32);
//开机自动进入Windows
RegistryKey sub_key0 = localKey.OpenSubKey(@"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon", true);
if (this.chk_auto_login_windows.Checked == true)
    sub_key0.SetValue("AutoAdminLogon", "1");
    sub_key0.SetValue("DefaultDomainName", "");
    sub_key0.SetValue("DefaultUserName", txt_auto_login_username.Text);
    sub_key0.SetValue("DefaultPassword", txt_auto_login_password.Text);
    sub_key0.SetValue("DontDisplayLastUserName", "1");
    sub_key0.SetValue("IgnoreShiftOverride", "1");
    foreach (string vname in sub_key0.GetValueNames())
        if (vname == "LegalNoticeCaption") { sub_key0.DeleteValue("LegalNoticeCaption"); }
        if (vname == "LegalNoticeText") { sub_key0.DeleteValue("LegalNoticeText"); }
        if (vname == "ForceAutoLogon") { sub_key0.DeleteValue("ForceAutoLogon"); }
        if (vname == "AutoAdminLogon") { sub_key0.DeleteValue("AutoAdminLogon"); }
        if (vname == "DefaultDomainName") { sub_key0.DeleteValue("DefaultDomainName"); }
        if (vname == "DefaultUserName") { sub_key0.DeleteValue("DefaultUserName"); }
        if (vname == "DefaultPassword") { sub_key0.DeleteValue("DefaultPassword"); }
        if (vname == "DontDisplayLastUserName") { sub_key0.DeleteValue("DontDisplayLastUserName"); }
        if (vname == "IgnoreShiftOverride") { sub_key0.DeleteValue("IgnoreShiftOverride"); }
sub_key0.Close();
//程序随PC启动
RegistryKey sub_key1 = localKey.OpenSubKey(@"SOFTWARE\Microsoft\Windows\CurrentVersion\Run", true);
string Path_str = System.Windows.Forms.Application.ExecutablePath;
if (this.checkBox_auto_start.Checked == true)
    sub_key1.SetValue("点晴MIS信息通后台服务程序", Path_str);
    sub_key1.DeleteValue("点晴MIS信息通后台服务程序");
sub_key1.Close();
localKey.Close();
该文章在 2021/2/18 22:39:00 编辑过
