【C#】asp.net之HTTP协议断点续传
2021年3月3日 17:39 本文热度 4650
using System;
using System.IO;
using System.Linq;
using System.Net;
using System.Text;
namespace HttpDemo
class Program
//需要下载的路径
static string url = "http://www.aseoe.com/demo/api/jquery_aseoe_001.zip";
//获取文件全称
static string fileName = Path.GetFileName(url);
//保存路径
static string localPath = "D:\\HttpCeShi\\" + fileName;
//未下载完后面加.temp后缀名
static string tempPath = localPath + ".temp";
//偏移量(断点)
static int pos;
DownLoad();
Console.ReadLine();
public static void DownLoad()
//如果存在要更新的文件就结束
if (File.Exists(localPath))
return;
Stream localfs = null;
//如果不存在未上传完文件(需断点续传文件)
if (File.Exists(tempPath))
localfs = new FileStream(tempPath, FileMode.Open);
localfs = new FileStream(tempPath, FileMode.Create);
//获取断点
pos = (int)localfs.Length;
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(url);
request.Headers.Add("Accept-Charset", "GBK,utf-8");
request.UserAgent = "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; .NET CLR 1.0.3705;)";
request.Method = "GET";
request.Timeout = 30000;
//文件总长度单位(B)
long total = request.GetResponse().ContentLength;
Console.WriteLine("总长度为:" + total);
if (pos > 0)
request.AddRange(pos);//偏移到断点
HttpWebResponse responseResult = (HttpWebResponse)request.GetResponse();
using (Stream stream = responseResult.GetResponseStream())
byte[] buffer = new byte[total - pos];
int readSize = stream.Read(buffer, 0, buffer.Length);
while (readSize > 0)
localfs.Write(buffer, 0, readSize);
Console.WriteLine("已下载:" + localfs.Length);
localfs.Close();
File.Move(tempPath, localPath);//将临时文件改为正常文件后缀
Console.WriteLine("下载完成!!!");
该文章在 2021/3/3 17:39:36 编辑过
