SQL Server企业管理器(Ssms.exe)命令行带参数自动登录并运行指定SQL语句
2021年6月17日 21:54 本文热度 3813
用法: ssms.exe [-S server_name [\ instance_name]] [-d数据库] [-U用户] [-P密码] [-E] [文件名[,文件名]] [/?]
[-S The name of the SQL Server instance to which to connect]
[-d The name of the SQL Server database to which to connect]
[-E] Use Windows Authentication to login to SQL Server
[-U The name of the SQL Server login with which to connect]
[-P The password associated with the login]
[file_name[, file_name]] names of files to load
[-nosplash] Supress splash screen
[/?] Displays this usage information
【C#代码】
       private void lblGoSqlSite_Click(object sender, EventArgs e)
            Clipboard.SetDataObject("127.0.0.1,250");       //复制SQL Server访问地址到剪贴板
            System.Diagnostics.Process.Start("Ssms.exe", "-S 127.0.0.1,250 -d clicksun -U sa -P clickSun%1532";
该文章在 2021/6/17 21:54:41 编辑过
