C#使用DirectoryEntry类操作Windows帐户
2021年6月26日 23:49 本文热度 5094
这几天使用C#操作windows帐户相当纠结,以前没做过,google翻阅了不少资料,尝试不少方法,终于解决了我的问题。
1.创建windows帐户
/// <summary>
/// 创建Windows帐户
/// </summary>
/// <param name="pathname"></param>
/// <returns></returns>
public static void CreateLocalUser(string username, string password, string description)
    DirectoryEntry localMachine = new DirectoryEntry("WinNT://" + Environment.MachineName + ",computer");
    var newUser = localMachine.Children.Add(username, "user");
    newUser.Invoke("SetPassword", new object[] { password });
    newUser.Invoke("Put", new object[] { "Description", description });
    newUser.CommitChanges();
    localMachine.Close();
    newUser.Close();
2.更改Windows帐户密码
/// <summary>
/// 更改Windows帐户密码
/// </summary>
/// <param name="username"></param>
/// <param name="oldPwd"></param>
/// <param name="newPwd"></param>
public static void ChangeWinUserPasswd(string username, string oldPwd, string newPwd)
    DirectoryEntry user = localMachine.Children.Find(username, "user");
    object[] password = new object[] { oldPwd, newPwd };
    object ret = user.Invoke("ChangePassword", password);
    user.CommitChanges();
    user.Close();
3.判断Windows用户是否存在
/// <summary>
/// 判断Windows用户是否存在
/// </summary>
public static bool ExistWinUser(string username)
    try
        using (DirectoryEntry localMachine = new DirectoryEntry("WinNT://" + Environment.MachineName + ",computer"))
            var user = localMachine.Children.Find(username, "user");
            return user != null;
    catch
        return false;
4.删除Windows用户
/// <summary>
/// 删除Windows用户
/// </summary>
public static bool DeleteWinUser(string username)
    try
            //删除存在用户
            var delUser = localMachine.Children.Find(username, "user");
            if (delUser != null)
                localMachine.Children.Remove(delUser);
        return true;
    catch
        return false;
5.启用/禁用windows帐户
/// <summary>
/// 启用/禁用windows帐户
/// </summary>
public static void Disable(string username, bool isDisable)
    var userDn = "WinNT://" + Environment.MachineName + "/" + username + ",user";
    DirectoryEntry user = new DirectoryEntry(userDn);
    user.InvokeSet("AccountDisabled", isDisable);
    user.Close();
操作windows帐户的方法的诀窍在于通过DirectoryEntry 实例调用Invoke,InvokeGet,InvokeSet这三个方法。此三个方法可以对对本机 Active Directory 对象调用方法。操作win帐户的Active Directory 对象就是IADsUser接口。DirectoryEntry 实例通过调用Invoke方法调用IADsUser接口的方法,如上面修改Windows帐户密码就是通过调用IADsUser接口的“ChangePassword”方法;通过InvokeGet和InvokeSet方法调用IADsUser接口的属性,如上面的启用/禁用windows帐户,调用IADsUser接口的“AccountDisabled”属性。IADsUser接口具体有什么方法和属性可参考:
http://msdn.microsoft.com/zh-cn/library/aa746340(v=VS.85).aspx
该文章在 2021/6/26 23:49:24 编辑过
