using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace Test1
        public Form1()
            InitializeComponent();
        private string filename = null;
        private void Form1_Load(object sender, EventArgs e)
            filename = Application.StartupPath + "\\Config.ini";
        /// <summary>
        /// 读取
        /// </summary>
        /// <param name="sender"></param>
        /// <param name="e"></param>
        private void Button_Read_Click(object sender, EventArgs e)
            string names = IniFunc.getString("Information", "Name", null, filename);
            string gender = IniFunc.getString("Information", "Gender", null, filename);
            string age = IniFunc.getString("Information", "Age", null, filename);
            string region = IniFunc.getString("Information", "Region", null, filename);
            TextBox_Name.Text = names;
            TextBox_Gender.Text = gender;
            TextBox_Age.Text = age;
            TextBox_Region.Text = region;
        /// <summary>
        /// 写入
        /// </summary>
        private void Button_Write_Click(object sender, EventArgs e)
            string names = TextBox_Name.Text;
            string gender = TextBox_Gender.Text;
            string age = TextBox_Age.Text;
            string region = TextBox_Region.Text;
            IniFunc.writeString("Information", "Name", names, filename);
            IniFunc.writeString("Information", "Gender", gender, filename);
            IniFunc.writeString("Information", "Age", age, filename);
            IniFunc.writeString("Information", "Region", region, filename);
        /// <summary>
        /// 清空
        /// </summary>
        private void Button_Clear_Click(object sender, EventArgs e)
            TextBox_Name.Text = string.Empty;
            TextBox_Gender.Text = string.Empty;
            TextBox_Age.Text = string.Empty;
            TextBox_Region.Text = string.Empty;
