核心思想是调用 WinAPI 中的 GetExtendedTcpTable 方法来获取所有活动的 TCP 连接的信息,包括进程ID等等,主要实现如下:
TcpConnectionTableHelper.cs:
using System.Threading.Tasks;
namespace TcpConnectionMonitor
 public class TcpConnectionTableHelper
 [DllImport("Ws2_32.dll")]
 static extern ushort ntohs(ushort netshort);
 [DllImport("iphlpapi.dll", SetLastError = true)]
 static extern uint GetExtendedTcpTable(IntPtr pTcpTable, ref int dwOutBufLen, bool sort, int ipVersion, TCP_TABLE_TYPE tblClass, int reserved);
 [StructLayout(LayoutKind.Sequential)]
 public struct MIB_TCPROW_OWNER_PID
 return BitConverter.ToUInt16(new byte[2] { localPort2, localPort1 }, 0);
 return BitConverter.ToUInt16(new byte[2] { remotePort2, remotePort1 }, 0);
 public struct MIB_TCPTABLE_OWNER_PID
 public uint dwNumEntries;
 MIB_TCPROW_OWNER_PID table;
 public static string GetIpAddress(long ipAddrs)
 System.Net.IPAddress ipAddress = new System.Net.IPAddress(ipAddrs);
 return ipAddress.ToString();
 catch { return ipAddrs.ToString(); }
 public static ushort GetTcpPort(int tcpPort)
 return ntohs((ushort)tcpPort);
 public static MIB_TCPROW_OWNER_PID[] GetAllTcpConnections()
 MIB_TCPROW_OWNER_PID[] tcpConnectionRows;
 uint ret = GetExtendedTcpTable(IntPtr.Zero, ref buffSize, true, AF_INET, TCP_TABLE_TYPE.TCP_TABLE_OWNER_PID_ALL, 0);
 if (ret != 0 && ret != 122)
 throw new Exception("Error occurred when trying to query tcp table, return code: " + ret);
 IntPtr buffTable = Marshal.AllocHGlobal(buffSize);
 ret = GetExtendedTcpTable(buffTable, ref buffSize, true, AF_INET, TCP_TABLE_TYPE.TCP_TABLE_OWNER_PID_ALL, 0);
 MIB_TCPTABLE_OWNER_PID table = (MIB_TCPTABLE_OWNER_PID)Marshal.PtrToStructure(buffTable, typeof(MIB_TCPTABLE_OWNER_PID));
 IntPtr rowPtr = (IntPtr)((long)buffTable + Marshal.SizeOf(table.dwNumEntries));
 tcpConnectionRows = new MIB_TCPROW_OWNER_PID[table.dwNumEntries];
 for (int i = 0; i < table.dwNumEntries; i++)
 MIB_TCPROW_OWNER_PID tcpRow = (MIB_TCPROW_OWNER_PID)Marshal.PtrToStructure(rowPtr, typeof(MIB_TCPROW_OWNER_PID));
 tcpConnectionRows[i] = tcpRow;
 rowPtr = (IntPtr)((long)rowPtr + Marshal.SizeOf(tcpRow));
 Marshal.FreeHGlobal(buffTable);
 return tcpConnectionRows;
public enum TCP_TABLE_TYPE : int
 TCP_TABLE_BASIC_LISTENER,
 TCP_TABLE_BASIC_CONNECTIONS,
 TCP_TABLE_OWNER_PID_LISTENER,
 TCP_TABLE_OWNER_PID_CONNECTIONS,
 TCP_TABLE_OWNER_MODULE_LISTENER,
 TCP_TABLE_OWNER_MODULE_CONNECTIONS,
 TCP_TABLE_OWNER_MODULE_ALL
public enum TCP_CONNECTION_STATE : int
Program.cs:
 static void MonitorTcpConnections()
 Console.WriteLine("Proto Local Address Foreign Address State PID");
 List<String> rows = new List<string>();
 int windowTop = Console.WindowTop;
 TcpConnectionTableHelper.MIB_TCPROW_OWNER_PID[] tcpProgressInfoTable = TcpConnectionTableHelper.GetAllTcpConnections();
 int tableRowCount = tcpProgressInfoTable.Length;
 for (int i = 0; i < tableRowCount; i++)
 TcpConnectionTableHelper.MIB_TCPROW_OWNER_PID row = tcpProgressInfoTable[i];
 string source = string.Format("{0}:{1}", TcpConnectionTableHelper.GetIpAddress(row.localAddr), row.LocalPort);
 string dest = string.Format("{0}:{1}", TcpConnectionTableHelper.GetIpAddress(row.remoteAddr), row.RemotePort);
 string outputRow = string.Format("{0, -7}{1, -23}{2, -23}{3, -16}{4}", "TCP", source, dest, (TCP_CONNECTION_STATE)row.state, row.owningPid);
 Console.SetCursorPosition(0, i + 1);
 Console.WriteLine("{0, -80}", outputRow);
 else if (rows[i] != outputRow)
 if (rows.Count > tableRowCount)
 int linesToBeCleared = rows.Count - tableRowCount;
 rows.RemoveRange(tableRowCount, linesToBeCleared);
 for (int i = 0; i < linesToBeCleared + 1; i++)
 Console.WriteLine("{0, -80}", " ");
 Console.SetWindowPosition(0, windowTop);
实现的效果是每 100ms 获取一次活跃 TCP 连接的状态,也就是说每秒大概会刷新10次,为了避免由于刷新频率过快导致闪烁的问题,通过调用 Console.SetCursorPosition 来对变化的数据进行部分刷新,同时为了避免滚动条存在时,Console 指针引起滚动条自动滚动到最后一行,使用 SetWindowPosition 来固定滚动条的位置。
输出结果举例:
该文章在 2022/11/17 10:05:16 编辑过
