| [点晴永久免费OA]C# 双击ListView出现编辑框可编辑,回车确认
					当前位置:点晴教程→点晴OA办公管理信息系统
					→『 经验分享&问题答疑 』
 1.
 2.
        [DllImport("user32")] 3.
        public static extern int GetScrollPos(int hwnd, int nBar); 4.
  5.
        private TextBox txtInput; 6.
  7.
        //获取点击项的位置 8.
        private void lViewPersonWork_MouseDoubleClick(object sender, MouseEventArgs e) 9.
        { 10.            try 11.            { 12.                ListViewItem item = this.lViewPersonWork.GetItemAt(e.X, e.Y); 13.  14.                //找到文本框 15.                Rectangle rect = item.GetBounds(ItemBoundsPortion.Entire); 16.                int StartX = rect.Left; //获取文本框位置的X坐标 17.                int ColumnIndex = 0;
//文本框的索引 18.  19.                //获取列的索引 20.                //得到滑块的位置 21.                int pos = GetScrollPos(this.lViewPersonWork.Handle.ToInt32(), 0); 22.                foreach (ColumnHeader Column in lViewPersonWork.Columns) 23.                { 24.                    if (e.X + pos >= StartX + Column.Width) 25.                    { 26.                        StartX += Column.Width; 27.                        ColumnIndex += 1; 28.                    } 29.                } 30.  31.                if (ColumnIndex < this.lViewPersonWork.Columns.Count - 1) 32.                { 33.                    return; 34.                } 35.  36.                this.txtInput = new TextBox(); 37.  38.
         //locate the txtinput and hide it.
txtInput为TextBox 39.                this.txtInput.Parent = this.lViewPersonWork; 40.  41.                //begin edit 42.                if (item != null) 43.                { 44.                    rect.X = StartX; 45.                    rect.Width = this.lViewPersonWork.Columns[ColumnIndex].Width;
//得到长度和ListView的列的长度相同                     46.                    this.txtInput.Bounds = rect; 47.                    this.txtInput.Multiline = true; 48.                    //显示文本框 49.                    this.txtInput.Text = item.SubItems[ColumnIndex].Text; 50.                    this.txtInput.Tag =
item.SubItems[ColumnIndex]; 51.                    this.txtInput.KeyPress += new
KeyPressEventHandler(txtInput_KeyPress); 52.                    this.txtInput.Focus(); 53.                } 54.            } 55.            catch (Exception ex) 56.            { 57.                58.            } 59.
} 60.  61.
//回车保存内容 62.
private void txtInput_KeyPress(object sender, KeyPressEventArgs e) 63.
{ 64.            try 65.            { 66.                if ((int)e.KeyChar == 13) 67.                { 68.                    if (this.txtInput != null) 69.                    { 70.
ListViewItem.ListViewSubItem lvst = (ListViewItem.ListViewSubItem)this.txtInput.Tag; 71.  72.                        lvst.Text = this.txtInput.Text; 73.  74.                        this.txtInput.Dispose(); 75.                    } 76.                } 77.            } 78.            catch (Exception ex) 79.            { 80.                 81.            } 82.
} 83.  84.
//释放文本框内容 85.        private void lViewPersonWork_selectedIndexChanged(object sender, EventArgs e) 86.
{ 87.            try 88.            { 89.                if (this.txtInput != null) 90.                { 91.                    if (this.txtInput.Text.Length > 0) 92.                    { 93.
ListViewItem.ListViewSubItem lvst = (ListViewItem.ListViewSubItem)this.txtInput.Tag; 94.  95.                        lvst.Text = this.txtInput.Text; 96.                    } 97.  98.                    this.txtInput.Dispose(); 99.                } 100.
            } 101.
            catch (Exception ex) 102.
            { 103.
                 104.
            } 105.
        } 该文章在 2022/12/22 20:41:39 编辑过 | 关键字查询 相关文章 正在查询... |
