| [点晴永久免费OA]C#创建并设置IIS网站应用程序池
					当前位置:点晴教程→点晴OA办公管理信息系统
					→『 经验分享&问题答疑 』
         /// <summary>         /// 创建应用程序池 IIS 7 默认是 FrameWork 4.0  集成模式         /// </summary>         /// <param name="appPoolName"></param>         /// <param name="maxProcesses">最大进程数</param>         /// <param name="queueLength">队列长度</param>         /// <param name="type">0为集成模式1为经理模式</param>         public static bool createAppPool7(string appPoolName, long maxProcesses,long queueLength,string type)         {             try             {                 ServerManager sm = new ServerManager();                 //判断是否存在应用程序池                 ApplicationPool appPool = sm.ApplicationPools[appPoolName];                 if (appPool == null)                 {                     sm.ApplicationPools.Add(appPoolName);                     ApplicationPool apppool = sm.ApplicationPools[appPoolName];                     if ("0".Equals(type))                     {                         apppool.ManagedPipelineMode = ManagedPipelineMode.Integrated;//托管管道为集成模式  ManagedPipelineMode.Classic为经典模式                     }                     else {                         apppool.ManagedPipelineMode = ManagedPipelineMode.Classic;//托管管道为经典模式  ManagedPipelineMode.Classic为经典模式                     }                     apppool.ManagedRuntimeVersion = "v4.0";  //当设置错误时,会在应用程序中创建一个不存在的版本,不会报错                     //应当检测当前电脑是否安装 FrameWork 4.0 ,并处理没有安装时该怎么办                     //apppool.QueueLength                     apppool.Recycling.DisallowOverlappingRotation = false;                     apppool.Recycling.PeriodicRestart.Time = TimeSpan.fromMinutes(0);                     apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("23:00:00"));                     apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("06:00:00"));                     apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("12:30:00"));                     apppool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("18:00:00"));                     apppool.Recycling.LogEventOnRecycle = RecyclingLogEventOnRecycle.Memory                         | RecyclingLogEventOnRecycle.Requests                         | RecyclingLogEventOnRecycle.ConfigChange                         | RecyclingLogEventOnRecycle.IsapiUnhealthy                         | RecyclingLogEventOnRecycle.OnDemand                         | RecyclingLogEventOnRecycle.PrivateMemory                         | RecyclingLogEventOnRecycle.Schedule                         | RecyclingLogEventOnRecycle.Time;                     apppool.Recycling.PeriodicRestart.Memory = 40960000;                     apppool.Recycling.PeriodicRestart.PrivateMemory= 0;                     apppool.ProcessModel.IdleTimeout = TimeSpan.fromMinutes(0);                     apppool.ProcessModel.MaxProcesses= maxProcesses;                     apppool.ProcessModel.ShutdownTimeLimit = TimeSpan.fromSeconds(120);//关闭时间限制设置为120秒                     apppool.QueueLength = queueLength;                     apppool.Cpu.Limit = 80000;                     apppool.Cpu.Action=ProcessorAction.KillW3wp;                     apppool.Failure.RapidFailProtection = false;                     apppool.AutoStart = true;                     sm.CommitChanges();                     apppool.Recycle();                 }                  else                 {                     //appPool.ManagedPipelineMode = ManagedPipelineMode.Integrated;//托管管道为集成模式  ManagedPipelineMode.Classic为经典模式                     if ("0".Equals(type))                     {                         appPool.ManagedPipelineMode = ManagedPipelineMode.Integrated;//托管管道为集成模式  ManagedPipelineMode.Classic为经典模式                     }                     else                     {                         appPool.ManagedPipelineMode = ManagedPipelineMode.Classic;//托管管道为经典模式  ManagedPipelineMode.Classic为经典模式                     }                     appPool.ManagedRuntimeVersion = "v4.0";  //当设置错误时,会在应用程序中创建一个不存在的版本,不会报错                     //应当检测当前电脑是否安装 FrameWork 4.0 ,并处理没有安装时该怎么办                     appPool.Recycling.DisallowOverlappingRotation = false;                     appPool.Recycling.PeriodicRestart.Time = TimeSpan.fromMinutes(0);                     appPool.Recycling.PeriodicRestart.Schedule.Clear();                     appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("23:00:00"));                     appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("06:00:00"));                     appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("12:30:00"));                     appPool.Recycling.PeriodicRestart.Schedule.Add(TimeSpan.Parse("18:00:00"));                     appPool.Recycling.LogEventOnRecycle = RecyclingLogEventOnRecycle.Memory                         | RecyclingLogEventOnRecycle.Requests                         | RecyclingLogEventOnRecycle.ConfigChange                         | RecyclingLogEventOnRecycle.IsapiUnhealthy                         | RecyclingLogEventOnRecycle.OnDemand                         | RecyclingLogEventOnRecycle.PrivateMemory                         | RecyclingLogEventOnRecycle.Schedule                         | RecyclingLogEventOnRecycle.Time;                     appPool.Recycling.PeriodicRestart.Memory = 40960000;                     appPool.Recycling.PeriodicRestart.PrivateMemory = 0;                     appPool.ProcessModel.IdleTimeout = TimeSpan.fromMinutes(0);                     appPool.ProcessModel.MaxProcesses = maxProcesses;                     appPool.ProcessModel.ShutdownTimeLimit = TimeSpan.fromSeconds(120);//关闭时间限制设置为120秒                     appPool.QueueLength = queueLength;                     appPool.Cpu.Limit = 80000;                     appPool.Cpu.Action = ProcessorAction.KillW3wp;                     appPool.Failure.RapidFailProtection = false;                     appPool.AutoStart = true;                     sm.CommitChanges();                     appPool.Recycle();                 }             }             catch             {                 return false;             }             return true;         } 该文章在 2023/1/19 0:49:15 编辑过 | 关键字查询 相关文章 正在查询... |
