C#对称加密(AES加密)每次生成的结果都不同的实现思路和代码实例
2023年3月22日 18:28 本文热度 1909
这篇文章主要介绍了C#对称加密(AES加密)每次生成的结果都不同的实现思路和代码实例,每次解密时从密文中截取前16位,这就是实现随机的奥秘,本文同时给出了实现代码,需要的朋友可以参考下。
思路:使用随机向量,把随机向量放入密文中,每次解密时从密文中截取前16位,其实就是我们之前加密的随机向量。
代码:
  1. public static string Encrypt(string plainText, string AESKey)
  2. RijndaelManaged rijndaelCipher = new RijndaelManaged();
  3. byte[] inputByteArray = Encoding.UTF8.GetBytes(plainText);//得到需要加密的字节数组
  4. rijndaelCipher.Key = Convert.fromBase64String(AESKey);//加解密双方约定好密钥:AESKey
  5. rijndaelCipher.GenerateIV();
  6. byte[] keyIv = rijndaelCipher.IV;
  7. byte[] cipherBytes = null
  8. using (MemoryStream ms = new MemoryStream())
  9. using (CryptoStream cs = new CryptoStream(ms, rijndaelCipher.createEncryptor(), CryptoStreamMode.Write))
  10. cs.Write(inputByteArray, 0, inputByteArray.Length);
  11. cs.FlushFinalBlock();
  12. cipherBytes = ms.ToArray();//得到加密后的字节数组
  13. cs.Close();
  14. ms.Close();
  15. var allEncrypt = new byte[keyIv.Length + cipherBytes.Length];
  16. Buffer.BlockCopy(keyIv, 0, allEncrypt, 0, keyIv.Length);
  17. Buffer.BlockCopy(cipherBytes, 0, allEncrypt, keyIv.Length * sizeof(byte), cipherBytes.Length);
  18. return Convert.ToBase64String(allEncrypt);
  19.
  20. public static string Decrypt(string showText, string AESKey)
  21. string result = string.Empty;
  22. try
  23. byte[] cipherText = Convert.fromBase64String(showText);
  24. int length = cipherText.Length;
  25. SymmetricAlgorithm rijndaelCipher = Rijndael.create();
  26. rijndaelCipher.Key = Convert.fromBase64String(AESKey);//加解密双方约定好的密钥
  27. byte[] iv = new byte[16];
  28. Buffer.BlockCopy(cipherText, 0, iv, 0, 16);
  29. rijndaelCipher.IV = iv;
  30. byte[] decryptBytes = new byte[length - 16];
  31. byte[] passwdText = new byte[length - 16];
  32. Buffer.BlockCopy(cipherText, 16, passwdText, 0, length - 16);
  33. using (MemoryStream ms = new MemoryStream(passwdText))
  34. using (CryptoStream cs = new CryptoStream(ms, rijndaelCipher.createDecryptor(), CryptoStreamMode.Read))
  35. cs.Read(decryptBytes, 0, decryptBytes.Length);
  36. cs.Close();
  37. ms.Close();
  38. result = Encoding.UTF8.GetString(decryptBytes).Replace("/0"""); ///将字符串后尾的'/0'去掉
  39. catch { }
  40. return result;
调用:
  1. string jiaMi = MyAESTools.Encrypt(textBox1.Text, "abcdefgh12345678abcdefgh12345678");
  2.
  3. string jieMi = MyAESTools.Decrypt(textBox3.Text, "abcdefgh12345678abcdefgh12345678");
该文章在 2023/3/22 18:28:42 编辑过
