点晴ERP-用于工单显示图片的还原路径函数
2023年8月28日 16:18 本文热度 1231
:点晴ERP-用于工单显示图片的还原路径函数
描述:只适用于显示一张图片,有多张图片时本函数不生效
Function regx(patrn, str)
 Dim regEx, Match, Matches
 Set regEx = New RegExp
 regEx.Pattern = patrn
 regEx.IgnoreCase = True
 regEx.Global = True
 Set Matches = regEx.execute(str)
 For Each Match in Matches
 RetStr = RetStr & Match.Value & " "
 Next
 regx = RetStr
End Function
Function decryption_imgpath (Y_images_path)
    if isNull(Y_images_path) then
    if Instr(Y_images_path,"read.ashx")>0 then
    Y_images_path_copy=Y_images_path
    Y_images_path_out=Y_images_path
    Y_images_path_copy=regx("src=.*?border",Y_images_path_copy)
    Y_images_path_copy=replace(Y_images_path_copy,"border","")
    Y_images_path_copy=replace(Y_images_path_copy,"src=","")
    Y_images_path_copy=replace(Y_images_path_copy,"""","")
     Y_images_path_copy=replace(Y_images_path_copy," ","")
    'response.write "11"&Y_images_path_copy
    Y_images_path=regx("img.*?uploadlog_code",Y_images_path)
Y_images_path=regx("c=2.*?uploadlog_code",Y_images_path)
Y_images_path=replace(Y_images_path,"c=","")
Y_images_path=replace(Y_images_path,"uploadlog_code","")
Y_images_path=replace(Y_images_path," ","")
Y_images_path=replace(Y_images_path,"&","")
Y_images_path=replace(Y_images_path,"amp;","")
set rs_all=server.createobject("adodb.recordset")
    sql_all="select * from mis_uploader_fileinf   where  visitcode like" & sqlstr("%"&Y_images_path&"%")
    'response.write sql_all
     rs_all.Open sql_all,conn,3,1
     if rs_all.recordcount>0 then
    file_physical_path=rs_all("file_physical_path")
    file_physical_path=replace(file_physical_path,"C:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"D:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"E:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"F:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"G:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"H:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"I:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"J:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"K:\ClickSun","",1,-1,1)
    file_physical_path=replace(file_physical_path,"\","/")
     end if
      rs_all.close
      Y_images_path_output=Replace(Y_images_path_out,Y_images_path_copy,file_physical_path)
      decryption_imgpath=Y_images_path_output
    end if
    end if
      End Function
该文章在 2023/8/28 18:30:34 编辑过
