C# 设置文件夹的访问权限
2023年9月10日 11:58 本文热度 1546
/// <summary>
/// 设置文件夹的ACL
/// </summary>
/// <param name="folderPath">文件夹路径</param>
/// <param name="userName">用户</param>
/// <param name="rights">权限</param>
/// <param name="allowOrDeny">拒绝访问</param>
/// <returns></returns>
public static bool SetFolderACL(
     string folderPath,
     string userName,
     FileSystemRights rights,
     AccessControlType allowOrDeny)
     //设定文件ACL继承
     InheritanceFlags inherits = InheritanceFlags.ContainerInherit | InheritanceFlags.ObjectInherit;
     return SetFolderACL(folderPath, userName, rights, allowOrDeny, inherits, PropagationFlags.None, AccessControlModification.Add);
/// <summary>
/// 设置文件夹的ACL
/// </summary>
/// <param name="inherits">ACL继承</param>
/// <param name="propagateToChildren">应用于子文件夹及子文件</param>
/// <param name="addResetOrRemove">修改类型</param>
     string folderPath,
     string userName,
     AccessControlType allowOrDeny,
     InheritanceFlags inherits,
     PropagationFlags propagateToChildren,
     AccessControlModification addResetOrRemove)
     bool result;
     //获取目录信息
     var folder = new DirectoryInfo(folderPath);
     //获取当前文件夹ACL
     var dSecurity = folder.GetAccessControl(AccessControlSections.All);
     //设置新的ACL规则
     var accRule = new FileSystemAccessRule(userName, rights, inherits, propagateToChildren, allowOrDeny);
     //修改文件夹ACL
     dSecurity.ModifyAccessRule(addResetOrRemove, accRule, out result);
     //应用新的ACL规则到文件夹
     folder.SetAccessControl(dSecurity);
     //返回结果
     return result;
调用方法:
var folderPath = System.AppDomain.CurrentDomain.BaseDirectory;
var userName = "Users";
SetFolderACL(folderPath, userName, FileSystemRights.FullControl, AccessControlType.Allow);
该文章在 2023/9/10 11:58:56 编辑过
