19个基本 JavaScript 方法
2024年10月13日 22:43 本文热度 1424
01.函数节流
/** Function throttling timer version */function throttle(callback: Function, delay: number) {   let timer: number | null   return function () {     if (timer) return     const args = arguments //Use closure to save parameter array     timer = setTimeout(() => {       callback.apply(null, args)       timer = null     }, delay)   }}
02.URL 解码和编码
/** Encode URL */function encodeURL(url: string, isComponent = true): string {   return isComponent ? encodeURIComponent(url) : encodeURI(url)}
/** Decode URL */function decodeURL(url: string, isComponent = true): string {   return isComponent ? decodeURIComponent(url) : decodeURI(url)}
03.使用JavaScript 获取全局 CSS 变量
/** * @description Use JS to get global css variables * @param cssVariableName variable name * @returns {string} variable value*/function getCssVariableValue(cssVariableName: string): string {   return getComputedStyle(document.documentElement).getPropertyValue(cssVariableName)}
04.使用 JS 设置全局 CSS 变量
/**  * @description Set global CSS variables with JS  * @param {string} cssVariableName variable name  * @param {string} cssVariableValue variable value  */function setCssVariableValue(cssVariableName: string, cssVariableValue: string): void {   document.documentElement.style.setProperty(cssVariableName, cssVariableValue)}
05.清除所有 cookies
/** * @description clear all cookies */function clearCookie(): void {   const keyList = document.cookie.match(/[^ =;]+(?=\=)/g) as string[] | null   keyList && keyList.forEach(key => (document.cookie = `${key}=0;path=/;expires=${new Date(0).toUTCString()}`))}
06.清除所有项目缓存
/** * @description Clear all project caches */function clearCache(): void {  window.localStorage.clear()  window.sessionStorage.clear()  const keyList = document.cookie.match(/[^ =;]+(?=\=)/g) as string[] | null  keyList && keyList.forEach(key => (document.cookie = `${key}=0;path=/;expires=${new Date(0).toUTCString()}`))}
07.通过名称获取 URL 查询参数
/**  * @description Get URL query parameters by name  * @param {string} key The key of the query parameter that needs to be obtained  * @param {string} url The link that needs to be parsed, the default is window.location.href  * @returns {string | null} obtained value corresponding to key  */function getQueryByName(key, url = window.location.href) {   const queryNameRegExp = new RegExp(`[?&]${key}=([^&]*)(?:&|$)`)   const queryNameMatch = url.match(queryNameRegExp)   return queryNameMatch ? decodeURIComponent(queryNameMatch[1]) : null}
08.登录页面时间前缀
/**  * @description time prefix of login page  * @returns {string} time prefix  */function timeFix(): string {   const time = new Date()   const hour = time.getHours()   return hour < 9 ? 'Good morning' : hour <= 11 ? 'Good morning' : hour <= 13 ? 'Good afternoon' : hour < 20 ? 'Good afternoon' : 'Good evening'}
09.登录页面上的欢迎信息
/**  * @description Welcome message on the login page  * @returns {string} random welcome message  */function welcome(): string {   const list = ['Long time no see, I miss you so much! ', 'Wait until the stars go to sleep before I miss you', 'We are open today']   return list[Math.floor(Math.random() * list.length)]}
10.递归深层复制
/**  * @description Make a deep copy of the incoming data and return it  * @param {any} source data source  * @returns {any} copied data  */function deepClone(source: any): any {   if (!source || typeof source !== 'object') return source   if (source instanceof Date) return new Date(source)   if (source instanceof RegExp) return new RegExp(source)   const target = Array.isArray(source) ? ([] as Record<any, any>) : ({} as Record<any, any>)   for (const key in source) target[key] = typeof source[key] === 'object' ? deepClone(source[key]) : source[key]   return target}
11.随机生成一个 UUID
/**  * @description Randomly generate a UUID  * @returns {string} generated uuid  */function getRandomUUID(): string {   const tempURL = URL.createObjectURL(new Blob())   const uuidStr = tempURL.toString()   const separator = uuidStr.includes('/') ? '/' : ':'   URL.revokeObjectURL(tempURL)   return uuidStr.substring(uuidStr.lastIndexOf(separator) + 1)}
function getRandomUUID(): string {   const fn = (): string => (((1 + Math.random()) * 0x10000) | 0).toString(16).substring(1)   return fn() + fn() + '-' + fn() + '-' + fn() + '-' + fn() + '-' + fn() + fn() + fn()}
12.随机布尔值
/**  * @description random boolean value  * @returns {boolean} true | false  */function getRandomBoolean(): boolean {   return Math.random() > 0.5}
13.反转字符串
/**  * @description reverse string  * @param {string} str string  * @returns {string} reversed string  */function reverseString(str: string): string {   return str.split('').reverse().join('')}
14.随机生成十六进制颜色
/**  * @description Randomly generates a color string in Hex format  * @returns {string} Color string in Hex format  */function getRandomHexColor(): string {   return `#${Math.floor(Math.random() * 0xffffff).toString(16)}`}
15.获取变量的真实类型
/**  * @description Get the real type of the variable  * @param {any} variable variable of any type  * @returns {string} variable type  */function getRawType(variable: any): string {   return Object.prototype.toString.call(variable).split(' ')[1].replace(']', '').toLowerCase()}
16.将文本复制到剪贴板
/**  * @description Copy text to clipboard  * @param {string} text The copied text  */function copyText(text: string): void {   // Whether to support navigator.clipboard attribute   const isClipboardApiSupported = window.navigator && window.navigator.clipboard   if (isClipboardApiSupported) {     window.navigator.clipboard.writeText(text)   } else {     const textarea = document.createElement('textarea')     textarea.readOnly = true     textarea.value = text     textarea.style.position = 'absolute'     textarea.style.top = '-9999px'     textarea.style.left = '-9999px'     document.body.appendChild(textarea)     textarea.select()     document.execCommand('copy')     textarea.remove()   }}
17.滚动到顶部
/**  * @description scroll to top  */function scrollToTop(element: HTMLElement): void {   element.scrollIntoView({ behavior: 'smooth', block: 'start' })}
18.滚动到底部
/** * @description scroll to bottom */function scrollToBottom(element: HTMLElement): void {  element.scrollIntoView({ behavior: 'smooth', block: 'end' })}
19.对象公共方法
const obj = { a: 1, b: 2, c: 3, d: 4 }//Object.keys()// Will return an array consisting of the given object's own enumerable propertiesObject.keys(obj) // ['a', 'b', 'c', 'd']//Object.values()// Returns an array of all enumerable property values of the given object itselfObject.values(obj) // [1, 2, 3, 4]//Object.entries()// Returns an array of key-value pairs for the given object's own enumerable propertiesObject.entries(obj) // [['a', 1], ['b', 2], ['c', 3], ['d', 4]]//Object.fromEntries()//Convert the list of key-value pairs into an object, which is the reverse operation of Object.entries()Object.fromEntries( [['a', 1], ['b', 2]]) // { a: 1, b: 2 }// hasOwnProperty()// Returns a Boolean value indicating whether the object has the specified attribute in its own properties (that is, whether it has the specified key)obj.hasOwnProperty('a') // trueobj.hasOwnProperty('fff') // false//Object.assign()// Used to copy the values of all enumerable properties from one or more source objects to the target object. It will return the target object.const target = { a: 1, b: 2 }const source = { b: 4, c: 5 }const result = Object.assign(target, source) // { ...target, ...source } has the same effectconsole.log(result) // {a: 1, b: 4, c: 5}
该文章在 2024/10/14 10:50:31 编辑过
