C#客户端WinForm实现Form表单格式自定义
2024年12月27日 21:37 本文热度 1385
using System;using System.Collections;using System.Collections.Generic;using System.ComponentModel;using System.ComponentModel.Design;using System.ComponentModel.Design.Serialization;using System.Data;using System.Drawing;using System.Linq;using System.Text;using System.Threading.Tasks;using System.Web.UI.Design.WebControls;using System.Windows.Forms;using YUTU.UIL.Common.Controls;
namespace WindowsFormsApp1{    public partial class Form3 : Form    {        public Form3()        {            InitializeComponent();        }
       private void Form3_Load(object sender, EventArgs e)        {            initDesign();            loadVisibleControl();        }
       /// <summary>        /// 定义        /// </summary>        DesignSurface surface;        IDesignerHost host;        Control root;        //List<Control> selectedControls = new List<Control>();
       /// <summary>        /// 设计窗体        /// </summary>        private void initDesign()        {            surface = new DesignSurface();            surface.BeginLoad(typeof(UserControl));
           Control designView = surface.View as Control;            panel1.Controls.Add(designView);            designView.Dock = DockStyle.Fill;            designView.Visible = true;
           host = (IDesignerHost)surface.GetService(typeof(IDesignerHost));            root = (Control)host.RootComponent;            root.Dock = DockStyle.Fill;
           //控制移动位置            ISelectionService selectionService = host.GetService(typeof(ISelectionService)) as ISelectionService;            selectionService.SelectionChanged += delegate            {                try                {                    ICollection collection = selectionService.GetSelectedComponents();                    if (collection.Count > 0)                    {                        foreach (Control item in collection)                        {                            label1.Text = "X:" + item.Location.X.ToString();                            label2.Text = "Y:" + item.Location.Y.ToString();                        }                    }                }                catch (Exception ex)                {                    MessageBox.Show(ex.Message);                }            };        }
       /// <summary>        /// 加载控件        /// </summary>        public void loadVisibleControl()        {            //可以加载不同类型的控件
           TextBoxEx tbe = (TextBoxEx)host.CreateComponent(typeof(TextBoxEx), "name");            tbe.LabelText = "姓名";            root.Controls.Add(tbe);
           TextBoxEx tbe1 = (TextBoxEx)host.CreateComponent(typeof(TextBoxEx), "class");            tbe1.LabelText = "班级";            root.Controls.Add(tbe1);
           TextBoxEx tbe2 = (TextBoxEx)host.CreateComponent(typeof(TextBoxEx), "age");            tbe2.LabelText = "年龄";            root.Controls.Add(tbe2);
           //ComboBoxEx cbe = (ComboBoxEx)host.CreateComponent(typeof(ComboBoxEx), "bbb");            //root.Controls.Add(cbe);
           //TextBox tb = (TextBox)host.CreateComponent(typeof(TextBox), "ccc");            //root.Controls.Add(tb);        }
主要用到的技术知识点:
DesignSurface 类
参考
定义
命名空间:
程序集:
System.Windows.Forms.Design.dll
为设计组件提供一个用户界面。
C#
public class DesignSurface : IDisposable, IServiceProvider
继承
Object
DesignSurface
实现
IDisposable  IServiceProvider
注解
类 DesignSurface 实现用户视为设计器的内容。DesignSurface 是用户操作以更改设计时功能的用户界面。DesignSurface 提供完全独立的设计图面。
类 DesignSurface 可以用作独立设计器,也可以与 DesignSurfaceManager 类结合使用,为托管多个 DesignSurface 对象的应用程序提供通用实现。
类 DesignSurface 可以单独使用,或者用户可以从中派生一个新类并增强行为。
类 DesignSurface 自动提供多个设计时服务。类 DesignSurface 在其构造函数中添加其所有服务。这些服务中的大多数都可以通过在受保护的 ServiceContainer 属性中替换它们来重写。若要替换服务,请重写构造函数、调用基,并通过受保护的 ServiceContainer 属性进行任何更改。在释放设计图面时,将释放添加到服务容器和实现 IDisposable 的所有服务。下表显示了类提供的默认可替换服务 DesignSurface 集。
阅读原文:https://mp.weixin.qq.com/s/NhlJtbw9i3gy-RqZnOEmuA
该文章在 2024/12/28 12:07:44 编辑过
