C#调用WebApi请求常用的两种方式
2025年1月2日 11:29
本文热度 3842
1.WebRequest方式
引用dll
using System.IO;
using System.Net;
using System.Threading.Tasks;
//Post
public static string HttpPost(string url, string body)
Encoding encoding = Encoding.UTF8;
HttpWebRequest request = (HttpWebRequest)WebRequest.Create(url);
request.Method = "POST";
request.Accept = "text/html, application/xhtml+xml, */*";
request.ContentType = "application/json";
byte[] buffer = encoding.GetBytes(body);
request.ContentLength = buffer.Length;
request.GetRequestStream().Write(buffer, 0, buffer.Length);
HttpWebResponse response = (HttpWebResponse)request.GetResponse();
using (StreamReader reader = new StreamReader(response.GetResponseStream(), Encoding.UTF8))
return reader.ReadToEnd();
//GET
public static string HttpGet(string url)
request.Method = "GET";
2.HttpClient 方式
static HttpClient client = new HttpClient();
//根据 ID 获取产品
static async Task<Uri> CreateProductAsync(Product product)
HttpResponseMessage response = await client.PostAsJsonAsync(
"api/products", product);
response.EnsureSuccessStatusCode();
// return URI of the created resource.
return response.Headers.Location;
//创建新产品
static async Task<Product> GetProductAsync(string path)
Product product = null;
HttpResponseMessage response = await client.GetAsync(path);
if (response.IsSuccessStatusCode)
product = await response.Content.ReadAsAsync<Product>();
return product;
//更新产品
static async Task<Product> UpdateProductAsync(Product product)
HttpResponseMessage response = await client.PutAsJsonAsync(
$"api/products/{product.Id}", product);
// Deserialize the updated product from the response body.
return product;
//删除产品
static async Task<HttpStatusCode> DeleteProductAsync(string id)
HttpResponseMessage response = await client.DeleteAsync(
$"api/products/{id}");
return response.StatusCode;
static async Task RunAsync()
client.BaseAddress = new Uri("http://localhost:64195/");
client.DefaultRequestHeaders.Accept.Clear();
client.DefaultRequestHeaders.Accept.Add(
new MediaTypeWithQualityHeaderValue("application/json"));
try
Product product = new Product
Name = "Gizmo",
Price = 100,
Category = "Widgets"
var url = await CreateProductAsync(product);
Console.WriteLine($"Created at {url}");
product = await GetProductAsync(url.PathAndQuery);
ShowProduct(product);
// Update the product
Console.WriteLine("Updating price...");
product.Price = 80;
await UpdateProductAsync(product);
// Get the updated product
// Delete the product
var statusCode = await DeleteProductAsync(product.Id);
Console.WriteLine($"Deleted (HTTP Status = {(int)statusCode})");
catch (Exception e)
Console.WriteLine(e.Message);
Console.ReadLine();
该文章在 2025/1/2 11:47:13 编辑过
