【C#】查询Windows服务器远程桌面RDP协议登录事件,获取并导出当前服务器用户登录记录
2025年2月14日 15:32 本文热度 2403
参考:https://github.com/uknowsec/SharpEventLog
简介:读取登录过本机的登录失败或登录成功的所有计算机信息,在内网渗透中快速定位运维管理人员。
输出:登录时间、源IP地址、域名、用户名、是否成功
原理:通过Win API 获取windows事件安全日志中ID为4624、4625的事件,提取事件中的关键信息。
源码参考:
using System;
using System.Diagnostics;
using System.Linq;
using System.Text;
namespace SharpEventLog
    class Program
            System.Console.WriteLine("");
            System.Console.WriteLine("Author: Uknow");
            System.Console.WriteLine("Github: https://github.com/uknowsec/SharpEventLog");
            if (args.Length == 0)
                System.Console.WriteLine("Usage: SharpEventLog.exe -4624");
                System.Console.WriteLine("       SharpEventLog.exe -4625");
            if (args.Length == 1 && (args[0] == "-4624"))
                EventLog_4624();
            if (args.Length == 1 && (args[0] == "-4625"))
                EventLog_4625();
        public static void EventLog_4624()
            EventLog log = new EventLog("Security");
            Console.WriteLine("\r\n========== SharpEventLog -> 4624 ==========\r\n");
            var entries = log.Entries.Cast<EventLogEntry>().Where(x => x.InstanceId == 4624);
            entries.Select(x => new
                x.MachineName,
                x.Site,
                x.Source,
                x.Message,
                x.TimeGenerated
            }).ToList();
            foreach (EventLogEntry log1 in entries)
                string text = log1.Message;
                string ipaddress = MidStrEx(text, " 源网络地址: ", " 源端口:");
                string username = MidStrEx(text, "新登录:", "进程信息:");
                username = MidStrEx(username, " 帐户名: ", " 帐户域: ");
                DateTime Time = log1.TimeGenerated;
                if (ipaddress.Length >= 7)
                    Console.WriteLine("\r\n-----------------------------------");
                    Console.WriteLine("Time: " + Time);
                    Console.WriteLine("Status: True");
                    Console.WriteLine("Username: " + username.Replace("\n", "").Replace(" ", "").Replace("\t", "").Replace("\r", ""));
                    Console.WriteLine("Remote ip: " + ipaddress.Replace("\n", "").Replace(" ", "").Replace("\t", "").Replace("\r", ""));
        public static void EventLog_4625()
            Console.WriteLine("\r\n========== SharpEventLog -> 4625 ==========\r\n");
            var entries = log.Entries.Cast<EventLogEntry>().Where(x => x.InstanceId == 4625);
                x.MachineName,
                x.Site,
                x.Source,
                x.Message,
                x.TimeGenerated
            }).ToList();
                    Console.WriteLine("Status: Flase");
        public static string MidStrEx(string sourse, string startstr, string endstr)
            string result = string.Empty;
            int startindex, endindex;
            startindex = sourse.IndexOf(startstr);
            if (startindex == -1)
                return result;
            string tmpstr = sourse.Substring(startindex + startstr.Length);
            endindex = tmpstr.IndexOf(endstr);
            if (endindex == -1)
                return result;
            result = tmpstr.Remove(endindex);
            return result;
使用说明
打开cmd.exe
> SharpEventLog.exe
Author: Uknow
该文章在 2025/2/14 15:36:03 编辑过
