C#强制关闭Windows操作系统指定端口进程
2025年3月6日 17:47 本文热度 1774
C#强制关闭Windows操作系统指定端口进程,以下是适配旧版本的完整代码(兼容 .NET Framework 4.0):
using System;
using System.Diagnostics;
using System.Net;
namespace ClosePortExample
    class PortCloser
        [StructLayout(LayoutKind.Sequential)]
        public struct MIB_TCPROW_OWNER_PID
            public uint state;
            public uint localAddr;
            public uint localPort;
            public uint remoteAddr;
            public uint remotePort;
            public uint owningPid;
        [DllImport("iphlpapi.dll", SetLastError = true)]
        static extern uint GetExtendedTcpTable(
            IntPtr pTcpTable,
            ref int pdwSize,
            bool bOrder,
            int ulAf,
            TCP_TABLE_CLASS tableClass,
            uint reserved = 0);
        public enum TCP_TABLE_CLASS
            TCP_TABLE_OWNER_PID_ALL = 5
        public static void ClosePort(int targetPort)
            int bufferSize = 0;
            GetExtendedTcpTable(IntPtr.Zero, ref bufferSize, true, 2, TCP_TABLE_CLASS.TCP_TABLE_OWNER_PID_ALL);
            IntPtr tcpTablePtr = Marshal.AllocHGlobal(bufferSize);
            try
                uint ret = GetExtendedTcpTable(tcpTablePtr, ref bufferSize, true, 2, TCP_TABLE_CLASS.TCP_TABLE_OWNER_PID_ALL);
                if (ret != 0) throw new Exception("获取TCP表失败,错误代码: " + ret);
                int entryCount = Marshal.ReadInt32(tcpTablePtr);
                IntPtr rowPtr = (IntPtr)((long)tcpTablePtr + 4);
                for (int i = 0; i < entryCount; i++)
                    MIB_TCPROW_OWNER_PID row = (MIB_TCPROW_OWNER_PID)Marshal.PtrToStructure(rowPtr, typeof(MIB_TCPROW_OWNER_PID));
                    rowPtr = (IntPtr)((long)rowPtr + Marshal.SizeOf(typeof(MIB_TCPROW_OWNER_PID)));
                    ushort port = (ushort)IPAddress.NetworkToHostOrder((short)row.localPort);
                    if (port == targetPort)
                        try
                            Process process = Process.GetProcessById((int)row.owningPid);
                            process.Kill();
                            Console.WriteLine($"已终止进程: {process.ProcessName} (PID: {process.Id})");
                        catch (ArgumentException)
                            Console.WriteLine($"未找到PID为 {row.owningPid} 的进程。");
                        catch (Exception ex)
                            Console.WriteLine($"终止进程时出错: {ex.Message}");
            finally
                Marshal.FreeHGlobal(tcpTablePtr);
            if (args.Length == 0 || !int.TryParse(args[0], out int port))
                Console.WriteLine("请输入有效的端口号。");
                return;
            try
                ClosePort(port);
                Console.WriteLine("操作完成。");
                Console.WriteLine($"错误: {ex.Message}");
验证步骤
  1. 以管理员身份运行程序:确保有权限终止进程。
  2. 使用 netstat -ano 检查端口状态
netstat -ano | findstr ":目标端口"
  1. 确认进程已终止:如果仍有残留,检查是否为 TIME_WAIT 状态(需等待 2 分钟)。
该文章在 2025/3/6 17:47:32 编辑过
