行转列和列转行在mysql和sqlserver一些实现对比
2025年6月14日 12:56 本文热度 2068
一、行转列
表结构如下
脚本如下
CREATE TABLE `t_student`  (  `Id` int NOT NULL AUTO_INCREMENT,  `Name` varchar(50CHARACTER SET utf8mb4 COLLATE utf8mb4_0900_ai_ci NOT NULL,  `Course` varchar(255CHARACTER SET utf8mb4 COLLATE utf8mb4_0900_ai_ci NULL DEFAULT NULL,  `Score` int NOT NULL DEFAULT 0,  PRIMARY KEY (`Id`) USING BTREE) ENGINE = InnoDB AUTO_INCREMENT = 3 CHARACTER SET = utf8mb4 COLLATE = utf8mb4_0900_ai_ci ROW_FORMAT = Dynamic;
-- ------------------------------ Records of t_student-- ----------------------------INSERT INTO `t_student` VALUES (1'学生1''语文'80);INSERT INTO `t_student` VALUES (2'学生1''数学'90);INSERT INTO `t_student` VALUES (3'学生1''英语'99);INSERT INTO `t_student` VALUES (4'学生2''语文'85);INSERT INTO `t_student` VALUES (5'学生2''数学'92);
1.MySQL实现方式
 select name,sum(case course when '语文' then score else 0 end)as '语文',sum(case course when '数学' then score else 0 end)as '数学',sum(case course when '英语' then score else 0 end)as '英语' from t_student group by name
2.Sql Server实现方式
2.1静态实现
  SELECT name,isnull([语文],0) as [语文],isnull([数学],0) as [数学],isnull([英语],0) as [英语]FROM (    SELECT name,course, score    FROM t_student) AS SourceTablePIVOT (    MAX(score)  -- 使用聚合函数    FOR course IN ([数学][语文][英语])  -- 指定要转换的列值) AS PivotTable;
2.2动态实现
DECLARE @columns NVARCHAR(MAX) = '';DECLARE @sql NVARCHAR(MAX) = '';-- 获取所有不重复的科目作为列名SELECT @columns = @columns + QUOTENAME(course) + ','FROM (SELECT DISTINCT course FROM t_student) AS tmp;SET @columns = LEFT(@columns, LEN(@columns- 1);  -- 移除最后一个逗号SET @sql = 'SELECT *FROM (    SELECT name, course, score    FROM t_student) AS SourceTablePIVOT (    MAX(score)    FOR course IN (' + @columns + ')) AS PivotTable;';EXEC sp_executesql @sql;
二、列转行
表结构如下
脚本如下
CREATE TABLE `t_student_2`  (  `Id` int NOT NULL AUTO_INCREMENT,  `Name` varchar(50CHARACTER SET utf8mb4 COLLATE utf8mb4_0900_ai_ci NOT NULL,  `yuwen` int NOT NULL DEFAULT 0,  `shuxue` int NOT NULL DEFAULT 0,  `yingyu` int NOT NULL DEFAULT 0,  PRIMARY KEY (`Id`) USING BTREE) ENGINE = InnoDB AUTO_INCREMENT = 6 CHARACTER SET = utf8mb4 COLLATE = utf8mb4_0900_ai_ci ROW_FORMAT = Dynamic;
-- ------------------------------ Records of t_student_2-- ----------------------------INSERT INTO `t_student_2` VALUES (1'学生1'889092);INSERT INTO `t_student_2` VALUES (6'学生2'908885);
1.MySQL实现方式
  select name,yuwen as 'score''语文' as 'course' from t_student_2 union all  select name,shuxue ,'数学' from t_student_2 union all  select name,yingyu ,'英语' from t_student_2
2.SQL SERVER实现方式
2.1静态实现
SELECT name, subject, scoreFROM (    SELECT name, shuxue, yuwen, yingyu    FROM t_student_2AS SourceTableUNPIVOT (    score FOR subject IN (shuxue, yuwen, yingyu)AS UnpivotTable;
2.2动态实现
-- 获取除ID外的所有列名SELECT @columns = @columns + QUOTENAME(column_name) + ','FROM information_schema.columnsWHERE table_name = 't_student_2' AND column_name != 'id' and column_name!='name';
SET @sql = 'SELECT name, subject, scoreFROM t_student_2UNPIVOT (    score FOR subject IN (' + @columns + ')) AS UnpivotTable;';
该文章在 2025/6/14 16:49:10 编辑过
