真正获取硬盘序号和型号及固件版本
2013年11月14日 22:12 本文热度 6367
建窗体,窗体放置1个ComBox,命名为cbDrive,1个ListBox,命名为lstMain,一个CommandButton,命名为cmdGo,添加如下代码:
Dim h As clsMainInfo
Private Sub cmdGo_Click()
    Dim hT As Long
    Dim uW() As Byte
    Dim dW() As Byte
    Dim pW() As Byte
    Set h = New clsMainInfo
    With h
        .CurrentDrive = Val(cbDrive.Text)
         lstMain.Clear
         lstMain.AddItem "当前驱动器: " & .CurrentDrive
         lstMain.AddItem ""
         lstMain.AddItem "硬盘型号: " & .GetModelNumber
         lstMain.AddItem "序列号: " & .GetSerialNumber
         lstMain.AddItem "固件版本: " & .GetFirmwareRevision
    End With
    Set h = Nothing
End Sub
Private Sub Form_Load()
    cbDrive.AddItem 0
    cbDrive.AddItem 1
    cbDrive.AddItem 2
    cbDrive.AddItem 3
    cbDrive.ListIndex = 0
End Sub
'-------------------添加类模块-------------------------
Option Explicit
Private Const VER_PLATFORM_WIN32S [color=#0000ff]=
0
Private Const VER_PLATFORM_WIN32_WINDOWS = 1
Private Const VER_PLATFORM_WIN32_NT = 2
Private Const DFP_RECEIVE_DRIVE_DATA = &H7C088
Private Const FILE_SHARE_READ = &H1
Private Const FILE_SHARE_WRITE = &H2
Private Const GENERIC_READ = &H80000000
Private Const GENERIC_WRITE = &H40000000
Private Const OPEN_EXISTING = 3
Private Const Create_NEW = 1
Private Enum HDINFO
    HD_MODEL_NUMBER
    HD_SERIAL_NUMBER
    HD_FIRMWARE_REVISION
End Enum
Private Type OSVERSIONINFO
    dwOSVersionInfoSize As Long
    dwMajorVersion As Long
    dwMinorVersion As Long
    dwBuildNumber As Long
    dwPlatformId As Long
    szCSDVersion As String * 128
End Type
Private Type IDEREGS
    bFeaturesReg As Byte
    bSectorCountReg As Byte
    bSectorNumberReg As Byte
    bCylLowReg As Byte
    bCylHighReg As Byte
    bDriveHeadReg As Byte
    bCommandReg As Byte
    bReserved As Byte
End Type
Private Type SENDCMDINPARAMS
    cBufferSize As Long
    irDriveRegs As IDEREGS
    bDriveNumber As Byte
    bReserved(1 To 3) As Byte
    dwReserved(1 To 4) As Long
End Type
Private Type DRIVERSTATUS
    bDriveError As Byte
    bIDEStatus As Byte
    bReserved(1 To 2) As Byte
    dwReserved(1 To 2) As Long
End Type
Private Type SENDCMDOUTPARAMS
    cBufferSize As Long
    DStatus As DRIVERSTATUS
    bBuffer(1 To 512) As Byte
End Type
Private Declare Function GetVersionEx _
    Lib "kernel32" Alias "GetVersionExA" _
    (lpVersionInformation As OSVERSIONINFO) As Long
Private Declare Function CreateFile _
    Lib "kernel32" Alias "CreateFileA" _
    (ByVal lpFileName As String, _
    ByVal dwDesiredAccess As Long, _
    ByVal dwShareMode As Long, _
    ByVal lpSecurityAttributes As Long, _
    ByVal dwCreationDisposition As Long, _
    ByVal dwFlagsAndAttributes As Long, _
    ByVal hTemplateFile As Long) As Long
Private Declare Function CloseHandle _
    Lib "kernel32" _
    (ByVal hObject As Long) As Long
Private Declare Function DeviceIoControl _
    Lib "kernel32" _
    (ByVal hDevice As Long, _
    ByVal dwIoControlCode As Long, _
    lpInBuffer As Any, _
    ByVal nInBufferSize As Long, _
    lpOutBuffer As Any, _
    ByVal nOutBufferSize As Long, _
    lpBytesReturned As Long, _
    ByVal lpOverlapped As Long) As Long
Private Declare Sub ZeroMemory _
    Lib "kernel32" Alias "RtlZeroMemory" _
    (dest As Any, _
    ByVal numBytes As Long)
Private Declare Sub CopyMemory _
    Lib "kernel32" Alias "RtlMoveMemory" _
    (Destination As Any, _
    Source As Any, _
    ByVal Length As Long)
Private Declare Function GetLastError _
    Lib "kernel32" () As Long
Private mvarCurrentDrive As Byte
Private mvarPlatform As String
Public Function GetModelNumber() As String
    GetModelNumber = CmnGetHDData(HD_MODEL_NUMBER)
End Function
Public Function GetSerialNumber() As String
    GetSerialNumber = CmnGetHDData(HD_SERIAL_NUMBER)
End Function
Public Function GetFirmwareRevision() As String
    GetFirmwareRevision = CmnGetHDData(HD_FIRMWARE_REVISION)
End Function
Public Property Let CurrentDrive(ByVal vData As Byte)
    If vData < 0 or vData > 3 Then
        Err.Raise 10000, , "Illegal Drive Number"
    End If
    mvarCurrentDrive = vData
End Property
Public Property Get CurrentDrive() As Byte
    CurrentDrive = mvarCurrentDrive
End Property
Public Property Get Platform() As String
    Platform = mvarPlatform
End Property
Private Sub Class_Initialize()
    Dim OS As OSVERSIONINFO
    OS.dwOSVersionInfoSize = Len(OS)
    Call GetVersionEx(OS)
    mvarPlatform = "Unk"
    Select Case OS.dwPlatformId
        Case Is = VER_PLATFORM_WIN32S
            mvarPlatform = "32S"
        Case Is = VER_PLATFORM_WIN32_WINDOWS
            If OS.dwMinorVersion = 0 Then
                mvarPlatform = "W95"
            Else
                mvarPlatform = "W98"
            End If
        Case Is = VER_PLATFORM_WIN32_NT
            mvarPlatform = "WNT"
    End Select
End Sub
Private Function CmnGetHDData(hdi As HDINFO) As String
    Dim bin As SENDCMDINPARAMS
    Dim bout As SENDCMDOUTPARAMS
    Dim hdh As Long
    Dim br As Long
    Dim ix As Long
    Dim hddfr As Long
    Dim hddln As Long
    Dim s As String
    Select Case hdi
        Case HD_MODEL_NUMBER
            hddfr = 55
            hddln = 40
        Case HD_SERIAL_NUMBER
            hddfr = 21
            hddln = 20
        Case HD_FIRMWARE_REVISION
            hddfr = 47
            hddln = 8
        Case Else
            Err.Raise 10001, "Illegal HD Data type"
    End Select
    Select Case mvarPlatform
        Case "WNT"
            hdh = CreateFile("\\.\PhysicalDrive" & mvarCurrentDrive, _
                GENERIC_READ + GENERIC_WRITE, FILE_SHARE_READ + FILE_SHARE_WRITE, _
                0, OPEN_EXISTING, 0, 0)
        Case "W95", "W98"
            hdh = CreateFile("\\.\Smartvsd", _
                0, 0, 0, Create_NEW, 0, 0)
        Case Else
            Err.Raise 10002, , "Illegal platform (only WNT, W98 or W95)"
    End Select
    If hdh = 0 Then
        Err.Raise 10003, , "Error on CreateFile"
    End If
    ZeroMemory bin, Len(bin)
    ZeroMemory bout, Len(bout)
    With bin
        .bDriveNumber = mvarCurrentDrive
        .cBufferSize = 512
        With .irDriveRegs
            If (mvarCurrentDrive And 1) Then
                .bDriveHeadReg = &HB0
            Else
                .bDriveHeadReg = &HA0
            End If
            .bCommandReg = &HEC
            .bSectorCountReg = 1
            .bSectorNumberReg = 1
        End With
    End With
    DeviceIoControl hdh, DFP_RECEIVE_DRIVE_DATA, _
                    bin, Len(bin), bout, Len(bout), br, 0
    s = vbNullString
    For ix = hddfr To hddfr + hddln - 1 Step 2
        If bout.bBuffer(ix + 1) = 0 Then Exit For
        s = s & Chr(bout.bBuffer(ix + 1))
        If bout.bBuffer(ix) = 0 Then Exit For
        s = s & Chr(bout.bBuffer(ix))
    Next ix
    CloseHandle hdh
    CmnGetHDData = Trim(s)
End Function
该文章在 2013/11/14 22:12:18 编辑过
